SL/R230: Sl 350 it does not work
Old Jul 18, 2019 | 06:09 PM
Ivan750's Avatar
Mercedes SL r230
Sl it does not work does not mark the kilometers
[font][font]Hola a todos. [/font][font]Mi historia de tener mi auto siempre soñado (sl350) ha empezado mal. [/font][font]Compré mi sl 350 del año 2005 hace tres días, ni siquiera tuve tiempo de presentarlo en el foro. [/font][font]Mi sorpresa fue que hoy, cuando fui a dar un paseo con mi automóvil, el motor no funciona. [/font][font]la batería está en buenas condiciones, el marcador enciende todo el trabajo, el motor gira pero no funciona. [/font][font]Hemos mirado y el gas llega al filtro de combustible. [/font][font]Estoy muy triste porque solo tengo 3 días con mi auto. [/font][font]Por favor, le pido que me ayude si conoce alguna solución a mi problema. [/font][font]gracias[/font][/font]
Old Jul 19, 2019 | 07:00 AM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Welcome to the forum. Sorry for your dilemma but don't give up.
My guess without getting a proper scan would be that either one of the Cam position sensors (4) or Crank position sensor (1) has failed. When the motor cranks but does not start that usually means that one of the position sensors has failed.
Since your SL350 is not sold in the US, try posting your problem in the W211 forum as their models do have the M272 motor.
Good luck,
Bob
File Type: pdf
Old Jul 19, 2019 | 07:31 AM
Ivan750's Avatar
Mercedes SL r230
Thank you very much for the help. Today I noticed that when I put the key in and take the key out of the lock to start it, it does not make any sound, if I remember correctly, taking out the key or putting the key in the ignition lock makes a sound and unlocks the steering wheel, my car With the key removed, the steering wheel is not blocked. Could it be the immobilizer of the car that does not work? I tried the two keys and none works.
Old Jul 19, 2019 | 11:00 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The R230 does not have a steering wheel lock, so you won't hear that "bzzzt" sound when inserting the key.
Old Jul 20, 2019 | 08:50 AM
Ivan750's Avatar
Mercedes SL r230
I thank you very much for your help and your effort in trying to help me. Yesterday a friend who has a Mercedes diagnosis machine came to my house, when doing a scan he told us that the crankshaft sensor failed, on Monday I will buy it and I hope that it will be the solution because I have not slept for two days thinking about the damn fault.
Old Jul 20, 2019 | 04:57 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Don’t be so worried! You bought a fantastic car that will forever keep on asking for your attention. But it’s worth it (or at least most of us here think so).
Old Jul 20, 2019 | 06:59 PM
Ivan750's Avatar
Mercedes SL r230
Thanks for the cheering
Old Jul 22, 2019 | 09:42 AM
Ivan750's Avatar
Mercedes SL r230
after several sleepless nights we discovered that what was not working was the sensor number 70 (you can see it in the photo) a fellow scanned the car and gave us a fault of that sensor, I installed it and the car works perfectly, the breakdown has cost me 24 euros. tonight I can sleep well and calm without thinking about the car.
Old Jul 23, 2019 | 04:01 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Glad to hear it was a simple fix! Enjoy your car and post some pictures!
Old Jul 24, 2019 | 12:22 PM
Ivan750's Avatar
Mercedes SL r230
Old Aug 1, 2019 | 05:26 PM
Ivan750's Avatar
Mercedes SL r230
Hi. After changing the crankshaft sensor, the car works perfectly but the kilometer counts only lines, does not dial any number. We have made a diagnosis and it does not give any fault. Can somebody help me? Thank you
Old Aug 1, 2019 | 11:27 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
This has nothing to do with replacing the CPS. It looks like your cluster is having problems. The odometer value is stored both in the cluster and the EIS (ignition switch). When they don't match, you get dashes like that. You either have a bad cluster, bad EIS, or a wiring issue.
