SL/R230: Hard top problem
Old Jul 24, 2019 | 05:35 PM
GladV's Avatar
Sl 500
Hard top problem
Can the hard top be opened manually on 2005 sl 500
Old Jul 25, 2019 | 12:34 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Welcome to the forum! Please take a moment to visit the User Control Panel and update your profile to include your car model and year, and your location (at least country). This information will then appear below your name and avatar on the left side panel next to each post you make. This will greatly help others to give you better information. If you are using the mobile version of the site, you will need to switch to the "full" version to get to the User Control Panel.
To answer your questions, yes, but not easily. The flaps must be operated and that's best done with SDS:
THis is the "manual close" document, but opening would be much the same, just reverse the appropriate steps:
http://benzbits.com/r230/Roof/ManualClose.pdf
And the flaps:
http://benzbits.com/r230/Roof/ManualCloseFlaps.pdf
Old Jul 25, 2019 | 10:58 AM
alk247's Avatar
2003 SL500
I did the manual close, but manual open did not work for me. Never could figure why, but roof did not get all the way down in the trunk and rear shelf never got in the horizontal position. I gave up and closed the roof.
Old Jul 25, 2019 | 12:07 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
A friend and I struggled with lowering the top on his car a couple of weeks ago. I think it is because the "Easy Pack" hydraulic cylinders are able to freely move and are not supporting the roof mechanism in their extended position.
On a separate matter, if your Dell D630 has a WiFi adapter, then I suggest you open Windows XP Control Panel and disable it. Last week I did this on my PC, and now XENTRY and DAS both open much, much quicker.
Old Jul 25, 2019 | 02:05 PM
Ivan750's Avatar
Mercedes SL r230
Hi Rudney, where are you looking for those photos with images that explain with doing tasks in Mercedes SL? I would like to have that information to assemble and disassemble some parts of my car. Thank you
Old Jul 25, 2019 | 10:41 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Most all of my docs and photos that I keep on my website come from SDS.
Old Jul 26, 2019 | 08:23 AM
Ivan750's Avatar
Mercedes SL r230
Thanks Rudeney, unfortunately I don't have any diagnostic machine and I can't have that kind of documents.
