SL/R230: Slow Clock?
Old Aug 5, 2019 | 07:49 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Slow Clock?
I know this is a 1st world problem, but my digital clock runs slow, each week it gets about 4-5 mins slow, I can easily correct this on the service menu, but I shouldn't have to should I?
Anyone else have this?
Alex
Old Aug 5, 2019 | 08:11 AM
Ivan750's Avatar
Mercedes SL r230
[font][font]También tuve que corregir el reloj de mi auto. [/font][font]No sé por qué sé cómo cambiar los minutos.[/font][/font]
Old Aug 5, 2019 | 09:13 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Hi Alex, you are in the wrong forum. This is the R230 SL forum. It looks like you have CLK230, which would be a W208 - try that forum.
Old Aug 5, 2019 | 12:04 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
He has an R230, Rodney -- a 500, I think.
I don't have any information about that center-dash clock display. Do you?
Old Aug 5, 2019 | 02:51 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Oh, I was just going by his profile.
I know the clock is tied to the COMAND module which sets the time from the GPS signals. I know there is a bug in the older COMAND systems that causes clock and date issues due to the way the GPS signal tracks the date. Instead of it sending the actual date, it sends a "week sequence number", which rolsl over ever 1,024 weeks. The bug in the COMAND software misinterprets the date based. For COMAND systems that display the date, ti will be wrong. For those that don;t it can just give the wrong time. I don't believe there is a fix except to have the instrument cluster coded for "does nto have COMAND" and then you can set the clock manually. But then you lose the navigation display aids in the cluster.
Old Aug 6, 2019 | 08:38 AM
A1EK's Avatar
HI
Sorry my thumbnail is my old CLK !
Old Aug 6, 2019 | 04:43 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Bobterry set me straight. The icon is no problem; mine still shows my W163 ML But do change your forum profile so the correct car is listed below your thumbnail and username!
Old Dec 14, 2019 | 12:22 PM
sivikvtec's Avatar
2005 SL65 AMG
Bump, I’m also having this issue.
My car is a 2005 and Command has been replaced with an aftermarket headunit.
I am able to set the time in the cluster menu, but it’s losing around one second per hour, which adds up to around 4-5 minutes after a week and a half.
Does anyone have schematic that shows where the actual device that keeps time is located? I’m guessing it’s not in the clock display itself, but embedded in the gage cluster circuit board?
Old Dec 14, 2019 | 04:27 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
... my digital clock runs slow, each week it gets about 4-5 mins slow, I can easily correct this on the service menu...
So what happens here, if I’m not mistaken, is that Alex corrects the time (I can only set the hours, or half hours, not sure) and that the algorithm takes over as soon as it has satellites in view. And resets the wrong time.
Old Dec 16, 2019 | 07:28 AM
A1EK's Avatar
I just use the comand unit, go into Serv (Service) then 'time and date' you can type in the minutes there.. I have to set it fast by 5 mins each week,
