SL/R230: 2004 Sl500 won't crank
Old Aug 17, 2019 | 01:45 PM
josecruz's Avatar
sl500
Relocated recently yo Tampa FL and got issues with my 2004 sl500, it simply won't crank. Car was seating for two months and bats on trickle chargers. I did check batteries and these are ok. Next, I did check starter relay and it does not have power on pin30 with keyfob in. In order to check the starter, I did send +12 VDC to it using a starter relay output pin (87) and crank super fast. But still, no engine crank using the key fob and or with the starter relay in place.
I did run my scanner but no codes.
What I have confirmed is working fine: Srarter, fuses (F29, F43) got this online, keyfob bat is new, trunk battery is new and crank battery is fine.
What I don't know:
- Why the starter relay (L) is not having power at pin (30) while the ignition keyfob is placed to start the engine. Will appreciate any help. jose427@gmail.com and or 787-560-3433.
God Bless.
Old Aug 19, 2019 | 03:39 AM
Ivan750's Avatar
Mercedes SL r230
Hi, I had an equal problem, I left my car running and the next day it did not start. The fault was the crankshaft sensor, I put it on again and the car started perfectly. To find that solution a friend put the diagnostic machine and She told us the car bug.
Old Aug 19, 2019 | 07:58 AM
josecruz's Avatar
sl500
Hi;
First, thanks for your reply.
One quick one; Did your car starter engage but after cranking it won't start? Usually, this is the crank sensor. Mine just won't engage the starter thus any crank at all. I did run an OBD2 scanner without any codes.
I appreciate your reply and help !!!
Be blessed;
JC
Old Aug 19, 2019 | 11:50 AM
Ivan750's Avatar
Mercedes SL r230
my car if I activate the starter motor but the car did not work, I changed the crankshaft sensor and everything was solved
Old Aug 19, 2019 | 12:07 PM
josecruz's Avatar
sl500
ok; thanks!!! Keep you posted once I work on it this coming weekend.
Jose.
Old Aug 19, 2019 | 03:47 PM
Ivan750's Avatar
Mercedes SL r230
good luck with the repair, I hope you can fix it yourself
