SL/R230: Crackling Cluster Panel Display
Old Aug 21, 2019 | 07:44 PM
JeffR230's Avatar
R230
Car is in the shop so no pic. I live in Florida. The speedometer and odometer display on 2006 SL500 looks like white crackling, like the heat is flaking a clear coating off. There is a clear plastic guard so nothing got into it unless a chemical of some sort managed to get in? Only Mercedes detailed the car or worked on the car so I don’t know. Is the only fix a replacement? If so, is it easy to DYI and is it plug and play or are there more computer issues or electrical issues to contend with?
Thank you!
Old Aug 23, 2019 | 05:22 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Are you saying the LCD panels are showing white pixels? You can replace them, but it requires disassembling the cluster. Do a forum search for "pink shrimp" and you should find ore info on that problem. You'll also then understand why "pink shrimp" is the search term.
