SL/R230: Motor and transmission mounts
First post. I bought a2006 SL55 and I see that the mounts were replaced at 50k miles. I now have 100k. Is this something that needs to be changed again or just the one time?
Thank you.
If the motor moves a lot, you need motor mounts.
Replace the trans mount at the same time as they last about the same as the motor mounts.
Thank you for the advice.
