SL/R230: Window stoppers
Clearly, from then on, the window will run up against the stoppers. However, I forgot to adjust the stoppers (you pull them down earlier in the process) and everything works just fine.
QUESTION: what function do the stoppers actually add to the cranking system?
Without the liner, the door doesn’t push the switch and the window swings in retracted. With the door closed, find the switch with your finger, push it, the window comes up, hold the switch and push up the two stoppers. Takes about 3 hands, patience and perseverance, but it can be done.
