SL/R230: loud knocking starting a cold engine.
I have a loud knocking sound when starting a cold engine. Lasts about 10-15 seconds and then this sound disappear. It comes from the left valve cover. The sound follows the engine speed and agrees that it knocks half the crankshaft speed. There is certainly something about the camshaft or rocker arms, valve lifters.
My question is does anyone know this problem and what was the fault on your engine?
We have a 2004 Lexus LX470 (190K miles, V8 gasoline) that makes a clacking noise for the first 10 seconds on a cold engine, and I assumed it was a lifter. It has done this for the past 3 years and seems a little worse (lasts longer) in the winter and less noticeable in the summer. The research on the Lexus/Toyota forums indicated that it was "piston slap" and is a common (normal) issue with older Lexus/Toyota V8 (UZJ100) engines, and to just drive it and not worry about it unless it got worse (louder or lasted longer). However, we also have a 2000 Toyota Landcruiser 160K miles (identical to the Lexus LX470 but with fewer miles), and it does NOT exhibit this behavior (yet?). I don't know if this is common in Mercedes or not, I not aware of it. But you might do some searching for piston slap.
In either case, @Rudeney 's advice of thinner oil might help.
Lee
The car has now 71000 mi. I don't drive much, aprox 2000 mi/year. Talking about oil I usually use Mobile 10W-30 synthetic oil. But have also tried different brand.
What oil quality do you use your cars?
My engine has now 216K km on the odo, and still use no oil.
But I don't see how the chain or it's driven components could create a knocking sound ?
Severe slag in the chain, and it hitting the engine block or chain cover housing, could explain it, but normally less slag sounds like a rattle, not like knocking.
If you are right, the chain tensioner should be changed, it's a known issue on the M272/273 engine, not that much on the M113 engine.
My money is still on a clogged up lifter.
The chain tensioner on the MM12/M113 engines is hydraulic, so this could get noisy. Replacement is fairly simple - just remover engine covers and the alternator for access. Torque is 80Nm.
The chain tensioner on the MM12/M113 engines is hydraulic, so this could get noisy. Replacement is fairly simple - just remover engine covers and the alternator for access. Torque is 80Nm.[/QUOTE]
Rodney, think about it, knocking from the chain, I doubt it, but on the other hand, sound is deceptive. What is knocking to one person is ticking to the other, and wise versa.
By the way, Mobil 1 ESP 5W30 have the following approvals.
MB-Approval 229.31
MB-Approval 229.51
MB-Approval 229.52
I will try the thin Mobil 0w40 oil and perhaps also add one can of additive. This should be interesting to hear the result.
Thanks for now
