SL/R230: Summer Prep
The car is an 04 SL 600 v12 with 74,000 miles.
You need a new mechanic, one familiar with ABC. Set aside an hour or so and read this.
No clue what grinding noises you are getting, maybe he screwed something up when replacing the strut. Might be best to have it flat-bedded to a reputable mercedes shop.
http://mercedes-abc-drive-carefully....rt-of.html?m=1
In regards to any banging/grinding noises, you or a qualified mechanic need to get the car up on a lift and look around.
Personally, I would not drive it if it’s making noises.
Replace the ABC filter afterwards.
If this doesn’t fix it, rebuild the valve block.
