SL/R230: R230 Need Help to guide me replacing the ABC line to the passenger rear strut
Hey,
I have a 2004 SL500 and the ABC went bad. I see that is leaking on the line that goes to the rear passenger strut. I removed the line and been dealing trying to install the new line.
I removed the 4 bolts to the sub-frame. The sub-frame lower just a little bit but it is difficult to pass the line all the way across from the valve block to the strut.
Any suggestions how can I complete the job without breaking the new line.
Thank you for your help,
Max
Max
Thank you for your response. I will send pics of underneath the car most likely Friday because tomorrow supposed to rain all day long.
As a reference I am replacing part# A230 997 0352.
Have a great rest of the day,
Maxi
Maxi
I added scheme of the parts as an additional information.
A230 997 0352
PRESSURE HOSE
FROM VALVE BLOCK REAR TO SUSPENSION STRUT REAR RIGHT
No.600 part on the pic below.
https://mercedes.7zap.com/en/eu/fg/c...2309970352#600
A230 997 0352
PRESSURE HOSE
[QUOTE=MB.Owner;7979560]I added scheme of the parts as an additional information.
A230 997 0352
PRESSURE HOSE
Below are pics of the car.
i started the job but I am having issues putting it back together.
I lowered the subframe a couple of inches.
if anyone can give me some guidance would be very appreciate it.
Below are some of the pics that I took under the car.
Please if anyone can help guiding me how to replace the ABC hydraulic line part #A230 997 0352
A230 997 0352
PRESSURE HOSE
