SL/R230: SL55 2003 no power after water leak
Please advise!!!
Disconnect the trunk battery and then the starter battery in the engine compartment. (load both of them externally,)
Then look for a connector sitting next to the roof hydraulic pump and the vacuum pump on the left side of the emergency wheel. Make sure the connector is dry and is not corroded.
After that check all fuses.
Reconnect the starter battery then the trunk battery.
Turn the key and pray it is fixed. ESD Warning will pop up, but thats normal after disconnecting the power.
