SL/R230: seat
Old Mar 15, 2020 | 01:19 PM
njbiker2008's Avatar
sl 500 r230
seat
sl500 r230 2006 on the seat the top button that make the seat go front and back the seat will go front but not back not door button the one on top of seat. do not know how to fix any help would be good t/k you
Old Mar 15, 2020 | 02:05 PM
matk's Avatar
R230 350SL
I’m not sure how feasible it is as I’ve never done it, but if the switch prises out from the seat, swap it over with the switch on the other seat. If the fault moves to the other seat, then it must be a faulty switch.
If the fault stays with the original seat then the switch must be good.
If the original seat with the problem can be powered back using the door card switches then the motors are all good, so my instinct based on what you’ve said, would be that it’s a switch problem,
Old Mar 15, 2020 | 03:34 PM
sl 500 r230
WOW Im a dumb *** I did not even think of that T/K you!!! How do you get it out of the seat do not want to mess up the seat?
Old Mar 15, 2020 | 03:39 PM
matk's Avatar
R230 350SL
I've never done it so wouldn't like to say but I'm sure someone else will be around to give more detail. I would have thought though, that it must be some sort of simple clip.
On another note though I had a few minutes spare time and found this, which if it works could be an easy solution....
https://www.benzworld.org/threads/tr...witch.1596588/
Old Mar 15, 2020 | 05:43 PM
sl 500 r230
MATK you are the man fix it in two min T/K you so much this place is the all that!!!!!!!!
Old Mar 16, 2020 | 05:10 AM
matk's Avatar
R230 350SL
Lol, happy to help, just wish every fault could be fixed that easily. Enjoy your car.
Old Mar 17, 2020 | 10:48 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
NOW I feel dumb. The thread with the solution tells you to ‘manually move the seat’. Does that mean using the control in the door, or does it mean forcing the seat for/backward along its rails with protein force?
Old Mar 18, 2020 | 07:20 AM
matk's Avatar
R230 350SL
Im guessing using the door card controls. I’m hoping to never have to find out lol
Old Mar 18, 2020 | 07:26 AM
Originally Posted by njbiker2008
fix it in two min
Biker knows...
Old Mar 18, 2020 | 10:11 AM
sl 500 r230
Yes I moved the seat back then forward then back with the door swich then i hit the seat switch and the seat went forward hit it agin and it went back!
Old Mar 18, 2020 | 10:13 AM
