SL/R230: recovery tank volcano
Old Apr 11, 2020 | 11:26 PM
twinturbov12's Avatar
04 sl 600,04 cayenne turbo,king ranch dually.
good evening guys and gals, i have an 04 sl 600 with 100k miles.when i shut the engine off the recovery tank will hold its breath for about ten minutes, then puke a half gallon through the blow off port at the lower side of the recovery tank.the blowoff port is utilized when the recovery tank cap does its spring activated magic at 21 psi ....which is equivalent to boiling point. anyway,ive removed the thermostat, replaced the recovery tank cap.still pukes shortly after shutdown.never overheats or loses fluid while driving.and is sporadic in its puke. im thinking weak water pump and have ordered that, along with a beck arnley 80 c stat.also on the way:;....new recovery tank and 010 upgrade intercooler pump. . anybody been through the same steamed situation that can relay a happy ending?
Old Apr 12, 2020 | 02:10 AM
pmercury's Avatar
member
CL
here you go
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 12, 2020 | 01:56 PM
recovery tank volcano part 3
thank you PMERCURY for the info relative to the recovery tank .
