SL/R230: 2005 SL500 R230 aftermarket Amp
If I were to get a decoder and hook my Fiber into it could I conceivably tie a new amp into my Bose system?
The part would be this.
https://www.ebay.com/itm/273605472993
Has anyone done this?
I have a aftermarket HU already installed as well.
Yes, I have done it, but I used the AVIN adapter, as the other ones on eBay or from Xtrons seem to have issues. I have been using my setup with a Kenwood HU for the past year without a single glitch.
it seems like adding another decoder would work in the same way?
On the other side of the coin, the reason most people opt for the optical converter is to keep the amp and speakers. The prevailing view is that the AMP and speakr qualit is more than adequate in this car, and considering the sound system was tuned for the car's acoustics, you can't do much better in sound quality.
yes, you can get a much "louder" output, and get that "thumper" feel, but if you're looking for good clean sound, the Bose or the HK amps are very good to start with.
Are the speaker wires fiber or can I grab them at the existing amp?
I would assume I would just need a 5 channel amp?
FYI, the rear speakers in the car are very small, and are intended primarily as surround fill-in, they're no intended to be driven at full volume. The center speaker in the dash, under the center dash clock is also used primarily for voice. When using a phone, or when play a DVD audio with a center channel output. The subwoofer is in the passenger footwell.
How all this works together is based on the Comand functions for surround sound decoding and the switching it does when you select different listening modes or when you use the built in phone. Once the Comand is removed, the amp cannot implement surround sound or use the center speaker. If you want to use the rear speakers as well as center channel with an aftermarket setup, you'll have to use an aftermarket amp as well. But be careful when driving the center channel and rear speakers, or you can blow them
