SL/R230: Hotline Archive: Hard top does not function
Customer Concern: Hard top does not function
Average Reported Mileage: 75673
Tests/Procedures:
1. Inspect for obvious damage to trunk hinges, luggage coverings, latches, and misalignments. Repair as needed. If side flaps are stuck or out of time, perform bulletin LI77.33-P-053085. Bulletin and pictures are attached under Related Documents.
2. Connect factory compatible scan tool and perform a complete system test. It is possible that faults in other control units not directly connected to the hard top to prevent operation.
3. Depending on Diagnostic Trouble Codes (DTC) found in control unit for the hard top. Perform testing per guided tests via scan tool. See the Diag information attached under Related Documents.
4. Without scan tool, perform operation of roof. If top goes into fault mode right away, you need a scan tool. If the top does not go into fault mode, listen for pump operation.
5. Pump is located in lower left corner of trunk. Check for bypass valve on pump being open. If pump does not run, inspect for blown fuse or faulty relay to pump. Tech Tips: Always check for updated service bulletins. New pumps come with bypass valve in the open position. Close valve before functioning roof. See Related Documents for manual operation for closing roof.
Confirmed Fix
7 - Replaced Convertible Top Hydraulic Pump
5 - Replaced Convertible Top Hydraulic Cylinder(s)
2 - Replaced Convertible Top Flap Assembly
2 - Replaced/Repaired Side Flaps Motor
2 - Replaced Convertible Top Micro Switch S117
2 - Replaced Load Compartment Limit Switch
1 - Replaced Hard Top Latch
1 - Replaced Convertible Top Hydraulic Pump Relay
1 - Repaired Convertible Top Flap Assembly and Replaced Convertible Top Hydraulic Pump Relay
1 - Aligned Convertible Top
1 - Repaired Roll Bar Hydraulic Cylinder
Confirmed Fix Details
Tech Reported Fix Details Confirmed Fix
1
October 23, 2019 2004 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
Convertible Top Hydraulic Pump Replaced Convertible Top Hydraulic Pump
2
September 15, 2016 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
3
June 7, 2016 2005 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
4
April 2, 2016 2005 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
- Pump was blowing the fuse.
27,500 miles Replaced Convertible Top Hydraulic Pump
5
May 28, 2014 2004 Mercedes-Benz SL600, 5.5L, V12, MFI, USA *
53,237 miles Replaced Convertible Top Hydraulic Pump
6
January 17, 2014 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
132,000 miles Replaced Convertible Top Hydraulic Pump
7
October 10, 2013 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
130,000 miles Replaced Convertible Top Hydraulic Pump
1
October 3, 2016 2004 Mercedes-Benz CLK500, 5.0L, V8, MFI, USA *
- Found leak at top actuating hydraulic cylinder. Do not try any fluid besides Mercedes top fluid, as further leaks will result. Replaced cylinders, top operating normal.
2
May 31, 2015 2005 Mercedes-Benz CLK500, 5.0L, V8, MFI, USA *
- LEft main actuator leaking. Replaced.
3
September 20, 2019 2005 Mercedes-Benz SL600, 5.5L, V12, MFI, USA *
38,500 miles Replaced Convertible Top Hydraulic Cylinder(s)
4
January 20, 2019 2005 Mercedes-Benz CLK500, 5.0L, V8, MFI, USA *
Convertible Top Hydraulic Cylinder(s) Replaced Convertible Top Hydraulic Cylinder(s)
5
September 6, 2016 2006 Mercedes-Benz SL500, 5.0L, V8, Des 113.963, USA *
1
December 20, 2015 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
Convertible Top Flap Assembly Replaced Convertible Top Flap Assembly
2
October 17, 2015 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
138,000 miles Replaced Convertible Top Flap Assembly
1
November 29, 2017 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
88,000 miles Replaced Convertible Top Micro Switch S117
2
December 10, 2016 2004 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
50,000 miles Replaced Convertible Top Micro Switch S117
1
March 21, 2018 2005 Mercedes-Benz SL600, 5.5L, V12, MFI, USA *
Load Compartment Limit Switch Replaced Load Compartment Limit Switch
2
October 18, 2016 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
1
February 12, 2016 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
Side Flaps Motor
61,000 miles Replaced Side Flaps Motor
2
August 27, 2014 2005 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
Side Flaps Motor
- One of the flaps was up and the other was stuck down.
62,000 miles Repaired Side Flaps Motor
1
February 16, 2016 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
Convertible Top
- The frame was bent. Repositioned the top frame and the top functioned.
77,000 miles Aligned Convertible Top
1
December 28, 2015 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
Convertible Top Hydraulic Pump Relay Repaired Convertible Top Flap Assembly and Replaced Convertible Top Hydraulic Pump Relay
1
April 27, 2015 2009 Mercedes-Benz SL550, 5.5L, V8, USA
30,250 miles Replaced Convertible Top Hydraulic Pump Relay
1
May 1, 2018 2003 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
Hard Top Latch
- the convertible top latch was leaking
1
March 17, 2018 2005 Mercedes-Benz SL500, 5.0L, V8, MFI, USA *
- Roll bar hydraulic ram was disconnected
