SL/R230: SL65 PSE Pump "harness"??
Old May 20, 2020 | 02:58 PM
SoftwareHollis's Avatar
SL65, W211 E55, W210 E55
I have a 2006 SL65 - I had a short circuit due to water in the trunk and it MELTED the socket that the PSE pump plugs into (and wrecked the PSE pump).
I've got a replacement PSE pump, but no idea how to connect it to the various wires that used to be attached to the wiring harness socket.
Does anyone know the part number for that wiring harness? Or have some sort of a diagram that shows which wire goes to which pin on the PSE pump for the SL65? There are 8 wires, not including the two wires that come from the microswitch and have their own plug.
I'd be incredibly grateful for any info or leads. Ive looked everywhere
Old May 20, 2020 | 03:05 PM
pmercury's Avatar
member
CL
you can buy the plug only
let me search
you can also go to the junkyard and cut one off
all sl's and probably other models have the same
Old May 20, 2020 | 04:01 PM
pmercury's Avatar
member
CL
sorry can't find the cable just cut one off on a R230
Old May 20, 2020 | 04:22 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by SoftwareHollis
Does anyone...have some sort of a diagram that shows which wire goes to which pin on the PSE pump for the SL65?
All of the wiring diagrams and electrical parts locator for your car are available as a small download here. From the main menu search for a diagram containing "PSE".
Old May 21, 2020 | 06:02 AM
DavidCA's Avatar
SL500 2009
SoftwareHollis
I have lots of these but I'm a bit far away. Here is the wiring info.
The W220 S-class and W215 CL-class have the same plugs, so that will help in a scrapyard / car breaker.
I have also attached the schematic.
10 way plug:-
1.
2. Red / White (thick) 12V
3. Green / Yellow
4. Green / Blue
5.
6. Brown (thick) ground
7. Black / Yellow
8. Brown / Blue
9. Brown / Red
10. Brown
6 way:-
1. Brown / Yellow
2.
3.
4.
5. Green / Orange
6.
File Type: pdf
Old May 21, 2020 | 03:37 PM
pmercury's Avatar
member
CL
funny to find out where they hide on epc
