SL/R230: Storing the car for a few months
Hi All
New Here Just purchased a 2004 Sl500 with 60000 miles. I am asking since I will not use the car for 4 months is it better to have the top down or up in the garage. It is hot in Florida and the garage gets in the 90s
thanks for your sage advice
Gene
Gene
Gene Fiorot (06-08-2020)
I believe is you disconnect batteries on this car you lose settings and codes. A Mechanic told me you have to keep power on the car with another source even when changing the batteries.
alexisvx (06-08-2020)
2007 SL550 & 2012 S550 4matic
Removing/disconnecting thee batteries is OK, given you disconnect in proper order, starting with trunk then engine and reversing on start-up front first trunks second. I believe you disconnect ground first on the batteries but you should search the forum on this procedure. Also know that on start-up, you will need to re-set window, radio stations, etc. Also procedures for this in this forum..
