SL/R230: Center Vent Programming
Old Jul 5, 2020 | 04:39 PM
OnePiece@aTime's Avatar
2003 SL500
As always, any hints on where to go next with the following situation is appreciated:
I’m getting a DAS error code after replacing the center vent: “the rotary potentiometers of the center vent must be reprogrammed when the center vent is replaced”
the DAS doesn’t provide the next step.
any ideas?
Thank you.
Old Jul 5, 2020 | 05:50 PM
pmercury's Avatar
member
CL
adaptation or initial startup
Old Jul 5, 2020 | 06:45 PM
2003 SL500
Thank you
Thank you, you got me in the right direction and it’s all set now.
Old Jul 5, 2020 | 06:47 PM
pmercury's Avatar
member
CL
my pleasure
Old Jul 5, 2020 | 07:19 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
You don't use Star Diagnosis/DAS for the potentiometers. You simply rotate each one fully in one direction, wait 10 seconds, then repeat for the opposite direction.
Old Jul 5, 2020 | 08:50 PM
2003 SL500
Thank you
The DAS just walked me through the process, and it specifically displayed the percentage open, which was helpful if not absolutely necessary.
