SL/R230: Question about PSE pump function.
So just fixed the trunk release air leaking problem. Sprayed it with soapy water to test and cycled it about 8 times. Seems to not be leaking as far as I can tell.
My question is how often is the pump supposed to cycle after actuating the trunk? It seems to cycle 4 or 5 times each time the trunk latch is actauted or a door opened.
It never times out, just turns on and off a number of times.
Thinking I may have another leak somewhere in the lock/seat mechanisms but wanted to know how a properly functioning system was supposed to act before chasing a potential non issue. It's had the trunk issue since I got it so I'm unfamiliar with the correct operation of things.
Thanks.
Thanks.
