SL/R230: How do I replace Refrigerant pressure and temperature sensor 1???
Here are the DTCs. Is sensor 1 the previously purchased For 2003-2006 Mercedes SL500 A/C Refrigerant Temperature Sensor 74425WH? Above the dryer? (See link below) If so, can I just unscrew the old one, and screw in the new one? Or will unscrewing the old one purge all of the refrigerant?
09152020 from Diaglink:
Read Codes
B1337-002
Stored&Current
B12/2 (Refrigerant pressure and temperature sensor 1) ( Refrigerant temperature ):The component is faulty or the lead has Open circuit.
B1338-002
Stored&Current
B12/2 (Refrigerant pressure and temperature sensor 1) ( Refrigerant pressure ):The component is faulty or the lead has Open circuit.
B1341 Stored&Current
Fault in communication with component H3 (Alarm signal horn).
Event memory
B1059-001 Current
Fault in CAN communication with control unit Driver signal acquisition and actuation module.
https://www.ebay.com/itm/For-2003-20...8AAOSwb91dZn6n
For 2003-2006 Mercedes SL500 A/C Refrigerant Temperature Sensor 74425WH 2004 2005
Seller: autopartsgeek
182 B12/2 (Refrigerant pressure 255.0 bar
and temperature sensor) Pressure value
Does this mean the Refrigerant pressure and temperature sensor is faulty?
See the codes and event memory below:
Read Codes
B1337-002 Stored&Current
B1338-002 Stored&Current
Event memory
B1059-001 Stored&Current
However, the B1059 sounds like this might be a communication issue with the SAM. See this thread for input: https://www.benzworld.org/threads/ai...o%20re%2Dcheck.
Your alarm siren (H3 in the left front fender well) is also faulty, which is common. You can replace it with just about any siren from many models, but it will fail again. See lots of threads on that issue.
Hydraulic oil may have fowled up the Refrigerant pressure and temperature sensor.
I spoke with a great mechanic yesterday. I showed him the codes and Diaglink data. I explained to him that I added 2 cans of refrigerant. He asked if I had oil in the sensor. I told him I cleaned hydraulic fluid out of the sensor and connector, got the compressor working, then added refrigerant. He confirmed that the sensor I ordered is the right one. He thinks the hydraulic oil caused the problem; and I compounded the problem by adding refrigerant after I cleaned oil out of the sensor and connector.
He proposed to evacuate the refrigerant, clean the sensor, and fill the system properly. I will wait and check readings with the new sensor connected to the wiring connector, and not installed on the dryer line; and see if the pressure reads zero, check the remaining codes, then try his solution. I may not even need the new sensor. I cleaned the sensor and connector again, and removed the wicking cloth tape around the wires. So, he may just need to correct the refrigerant level.
Some of my old readings 6 months ago show 9 bars pressure. Today it shows 555 bars pressure. I probably overfilled it. But that super high reading seems like the sensor is messed up. About 6 months ago I had hydraulic fluid reservoir burp up quarts several times before I fixed the suspension. Fluid wicks its way up cloth tape into sensors.
The sensor won’t arrive until next week. If the diagnosis and solution are not as described here, I will let you know.
this just happened following my coilover conversion where my indy mechanic also coded out the ABC function so I have zero malfunction alerts on the dash and the ABC button doesnt illuminate (1 or 2 red dots dont show up) anymore... am wondering if that ABC module he coded out has anything to do with this? likely not but thought i would mention... any help would be greatly appreciated. thanks
