SL/R230: What can I do to stop this
Old Oct 2, 2020 | 06:14 PM
Paulito0331's Avatar
2004 sl500
I have pulled the parkatronic fuse and then the disatronic fuse at different times and this still happens. This has got to stop. There will be nobody or nothing close to me. No curbs or cars. Where is the speaker can I remove it. Lol.
File Type: mov
Old Oct 2, 2020 | 07:19 PM
sivikvtec's Avatar
2005 SL65 AMG
I don’t know what that sound is, but my Parktronic definitely doesn’t sound like that.
Old Oct 2, 2020 | 07:45 PM
whoover's Avatar
'19 E63S sedan
It could be a bad sensor always detecting something. A scan will spot that quickly.
Old Oct 2, 2020 | 08:06 PM
LaciCLK320's Avatar
C300, CLK320(sold)
Did you run over a chipmunk?
Old Oct 3, 2020 | 02:34 AM
pmercury's Avatar
member
CL
bad sensor, wire.
need replacement, then calibration on Xentry/Das
takes 1 min to locate in Diag
Old Oct 3, 2020 | 09:14 AM
2004 sl500
Happen to be close to Houston,TX.
Old Oct 3, 2020 | 09:21 AM
2004 sl500
Can you test them individually with a ohm meter?
Old Oct 3, 2020 | 09:58 AM
pmercury's Avatar
member
CL
yes
sure
you have only one failing
just compare and you'll find
Old Oct 3, 2020 | 11:44 AM
whoover's Avatar
'19 E63S sedan
Getting to them involves removing the bumpers, which is a lot more work than having someone scan. Plus, diagnosing a pulse width out of spec on a sonar system with an ohmmeter will be a crap shoot. The first thing to do is visually inspect the sensors. If you see a tiny ding from a rock on one, that's your problem.
