SL/R230: Help
Old Nov 15, 2020 | 08:42 AM
foxifox's Avatar
Mercedes Benz SL500 R230
Help
Hi!
I just discovered that my SL 500 2003 was missing two plugs. Help me find out what they are called and what their catalog number is, please.
Look at the photo.
Old Nov 15, 2020 | 09:55 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Very common problem in the r230
just google r230 missing flap and you’ll see many results:
https://mbworld.org/forums/sl-class-...er-called.html
Old Nov 15, 2020 | 11:49 AM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
Originally Posted by foxifox
Hi!
Look at the photo.
Mine is missing those also. The plastic hinges broke and they were hanging there at an odd angle just waiting to blow away in the wind so I pulled them the rest of the way off. I'm not sure how to fix the broken hinges so I left it like yours - two open holes.
Old Nov 15, 2020 | 02:17 PM
Das Geld 2's Avatar
SL55, S500
welcome to 230 life
Old Nov 15, 2020 | 02:24 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
You have to buy that whole wing panel. The good news is that they are still available. The bad news is that you need to bring an extra fat wallet for the black ones. I have never been able to figure out how Mercedes prices parts and this is a good example:
23069009419C83 (2003, black, left) $920 list
23069010419C83 (2003, black, right) $1240 list
23069009417F08 (2003, gray, left) $436 list
23069010417F08 (2003, gray, right) $420 list
After discounts, that's about $600 for a gray pair and $1600 for a black pair. There are a couple of guys selling just the flaps, but they are expensive and probably don't match exactly. You can buy the wing panels used, but the hinges on those will probably be failed or failing. There are some DIY and purchased solutions for the hinge problem (assuming that you still had the flaps), but I'm not overly impressed by any of them. I am currently working on my own solution using a 3D printed hinge assembly that I will print in nylon on an industrial grade printer.
