SL/R230: Driver Window problem
Old Dec 19, 2020 | 03:24 AM
matk's Avatar
R230 350SL
Hi All
The driver window on my car started behaving eratically, it would not respond to switch inputs, then it started moving randomly in the opposite direction. Ie if I selected up it would move down.
Then finally it’s stopped moving at all. Won’t do the 1cm drop either when you open the door either.
I’ve checked fuses which are all OK. Any ideas where to start investigating? Which modules should I look at.
thanks, Mat
Old Dec 19, 2020 | 04:54 AM
pmercury's Avatar
member
CL
Might be your motor that deceased
here some prints to help you open up the door
If you have Xentry/Das, you can diagnostic this in minutes with Test, Actuation and Actual Values
always mention Make Year when it come to electronics
Old Dec 19, 2020 | 09:52 AM
BenzNinja's Avatar
Former Vendor
This is the procedure in Xentry/Das
Old Dec 19, 2020 | 11:53 AM
matk's Avatar
R230 350SL
Thank you both for your help, very kind of you. Peter its a 2005 350SL
Old Dec 19, 2020 | 07:10 PM
Gene Fiorot's Avatar
SL500
Mess with the best die like the rest. Nice Job Peter!
Old Dec 21, 2020 | 10:39 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
I've replaced 2 window regulators, but they did not behave like this when broken. I even have a spare window motor to test with now, but I think it would be too expensive to ship overseas to you.
Erratic behavior sounds like a bad module for the window controller, or relays in the controls.
Old Feb 18, 2021 | 07:39 AM
matk's Avatar
R230 350SL
Originally Posted by bobterry99
Weird.
If I were using Star Diagnosis, from the main menu for the door control module I would go to Actual values > Power windows > Relays, switches, operating elements. That leads to the screen seen below which shows all of the basic info to troubleshoot this problem: The current drawn by the motor, whether or not motion is blocked from an obstruction or the roof controller, and the input from the window control switch. It's apparent that the software for the Foxwell is patterned after Star Diagnosis, so I'd expect all statuses seen below to appear with the $110 tool.
As mentioned before, you can not control the window motor from Star Diagnosis. The motor can only be actuated from its control switch on the door panel.
OK
Finally got around to digging into this as the weather is improving.
I can confirm my Foxwell gives me the same screen checks as above. Ive been through them all and all relays, switches are activating and showing normal, however current consumption is a big fat zero.
So some follow up questions.........
1. Is this starting to feel like a motor issue?
2. I can't get out of my head that just before the failure the window had started working erratically, up when commanded down and vice versa etc. In my experience if a window motor goes bad it just stops working. While I look at getting the motor out is their anything else I should look at controller wise?
Many thanks in advance for any help.
Old Feb 18, 2021 | 09:33 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Remove door panel, unplug connector 11 on door control module, check voltage between pins 4 & 5 on the connector 11 socket (on the module, not the wire) as you press the window switch up and down. If you do not have voltage and there is power to the module, you have a bad module. If you have power, the problem is the motor or the wiring to the motor.
Old Feb 18, 2021 | 09:55 AM
Gonkey's Avatar
2006 SL600
Originally Posted by matk
Hi All
thanks, Mat
I had same kind of problem with mine last month. My SL600 did the strange input reversal . Turned out after disassembly that the window regulator cables had gotten all bound up under the motor .Replaced the window regulator and all is well now. HTH
Old Feb 18, 2021 | 10:01 AM
Gonkey's Avatar
2006 SL600
Old Feb 18, 2021 | 10:31 AM
matk's Avatar
R230 350SL
Some really good suggestions there, thank you.
