SL/R230: Got it.
Old Dec 24, 2020 | 11:27 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Got it. (SmartTop by Mods4Cars)
Yes!
Old Dec 24, 2020 | 12:24 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
I installed one a couple of years ago--you will love it !
Old Dec 24, 2020 | 12:32 PM
sivikvtec's Avatar
2005 SL65 AMG
Haha, yep it’s awesome.
Two things that caught me off guard:
1) When you raise the top, the back windows ALWAYS go up, even if you use the top up with windows down function. Mods4Cars confirmed this was normal.
2) The one touch all windows up/down with the roof switch works like this: double click the roof switch like a computer mouse and all windows go down, pull double click on the switch and all windows go up.
Old Dec 24, 2020 | 02:04 PM
next2pool's Avatar
I don't drive the car that often so I usually forget the sequence for the top and windows. My favorite is being able to control the top with my key FOB
Old Dec 25, 2020 | 07:28 AM
Yes, thanks, looking forward to it all, especially spring! I'm not that excited about splicing those 3M clamps into the wiring, cutting and plugging seems the more solid way to go.
Old Dec 25, 2020 | 11:26 PM
Das Geld 2's Avatar
SL55, S500
Remind me what this does again? The stock keyfob opens and closes the top with a push of the button
Was it to do it in motion?
Old Dec 25, 2020 | 11:43 PM
sivikvtec's Avatar
2005 SL65 AMG
The stock keyfob only lowers the top if you have it practically touching the infrared sensor on the door handle. This module allows you to do this via RF from a distance.
It also lets you raise/lower the the top while the car is moving, put all four windows up/down with a few taps of the roof switch, allows the roof to be raised/lowered without keeping the roof switch pressed/pulled the whole time and puts all of the windows down when the top is lowered.
Old Dec 26, 2020 | 01:49 PM
BeMyWn's Avatar
SL600
I am interested, what is the cost of this thing?
Old Dec 26, 2020 | 03:20 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Originally Posted by bobterry99
I find the module will also permit me to open the roof when electrical consumers are offline, thus bypassing a limitation programmed into the roof controller.
mine does not let me do this! Even with the smarttop module I have to wait...is there a secret you know of that I do not?
Old Dec 26, 2020 | 10:38 PM
sivikvtec's Avatar
2005 SL65 AMG
around $350 on eBay
Old Dec 27, 2020 | 12:10 PM
Hmmm I did not expect the manuals (plural) to be that un-straightforward. On their site, mods4cars adresses a problem that folks have had like this:
"Problem:
Even after trying all connectors the LED on the module still only lights up solid, none of the plugs produces a blinking LED.
Possible Cause:
The most common cause is reversed polarity on one of the CAN plugs. Unfortunately the polarity is different between SL and CLK/SLK, so the wiring harness can not be shipped pre-assembled.
Make sure the wires are inserted into the plugs correctly: Red wire in slot 1 and black wire on slot 2 (SLK and CLK). Red wire in slot 2 and black wire in slot 1 (SL).
The slot numbers are embossed on the backs of the plugs. Use good lighting and, if necessary, a magnifying glass."
All that implies that the photos in the instructions show wrong polarity for our SL's. Did you guys indeed connect the plugs contrary to what the illustrations indicate?
Thanks!
Old Dec 27, 2020 | 01:02 PM
next2pool's Avatar
I followed the instructions and it worked right out of the box--I do recall the polarity uncertainty but apparently I lucked out. The pictures were adequate as well.
Old Dec 27, 2020 | 01:36 PM
sivikvtec's Avatar
2005 SL65 AMG
Check this video out
Old Dec 30, 2020 | 03:44 AM
Got the module installed, all fine. It wasn’t exactly a plug and play experience, though. The wiring in there is way too short and tight, for me to work on without removing the side panel. But it’s a holiday and the weather stinks, so time wasn’t the issue. Jamming the +12V lead in the plug and securing it with a tie wrap is a good idea, bobterry99. Of course I first soldered the wire and it got firmly stuck at the first try. Thanks for the response folks.
Old Dec 30, 2020 | 05:53 PM
Oh, and the illustrations in the manual do indeed show the strand colors in the plugs reversed, when you install the module in an R230.
Old Dec 30, 2020 | 06:28 PM
sivikvtec's Avatar
2005 SL65 AMG
Maybe there’s some differences between models/regions/years but on my 2005 US spec SL65, everything matched the instructions from what I can remember.
Old Dec 31, 2020 | 07:26 AM
rune solem's Avatar
SL 55 and a GT 3000 vr4 Here's my car: http://home.online.no/~ludvs/index.cfm
The top should NOT be lowered or raised while in motion due to the metal roof, on cars with fabric that's another matter because of the weight.
