SL/R230: daylight clock
Old Mar 11, 2021 | 11:51 AM
rmp65's Avatar
sl65
daylight clock
How dp you set the clock ahead on 06 sl 500 Thanks.
Old Mar 18, 2021 | 08:12 AM
Tokyoite's Avatar
SL500 R230
common issue. videos even released for the simple procedure.
Old Mar 18, 2021 | 09:26 AM
chad500sl's Avatar
2017 SL550 (R231), 2021 E350 (W213)
In an 06, one option is the settings menu in the dash. Note that if the Time option is set to "sync with head unit" is on, then the setting menu is disabled. You'll need to use the second option, the SERV menu in the NTG1 command unit.
