SL/R230: Clock on Dash-2004 SL500
Old Apr 19, 2021 | 08:02 AM
bdenney61's Avatar
SL500
Purchased my 2004 SL500 in October, 2019
I have a all of the supplied manuals in a nice leather holder. I can
find most control changes in the manual but not this clock.
Very minor issue. Just a nuisance.
How do you set the time on the clock in the dash?
Side note- I am using the Turtle Wax, Hybrid Ceramic Wet Wax after my washes.
I think I am noticing a improve shine.
Thanks,
Bill
Old Apr 19, 2021 | 07:01 PM
Ghostty's Avatar
2005 SL500, 2015 CLS400
On the dash in the middle? Through the settings option on the radio / COMMAND screen.
Old Apr 20, 2021 | 03:30 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Thanks,
Bill
I take it you mean the clock on centre of dash board at windscreen?
Use you Comand to change, I recall Service button, then Time / Date I think.
Old Apr 20, 2021 | 05:47 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
The clock algorithm translating the satellite 'time signal' has a built in fault that (in my country) results in a 5 minute time fault. Compare it to something like a millenium bug. You can only set the hours (and perhaps steps of 30 minutes, I forgot about that one). If you want to free the clock from the faulty algorithm and adjust it by hand it needs to be digitally disconnected from the Comand unit. Others may chime in on that. I just live with the error.
Old Apr 20, 2021 | 10:49 AM
Tokyoite's Avatar
SL500 R230
just goo goo it!
Old Apr 20, 2021 | 10:51 AM
Tokyoite's Avatar
SL500 R230
Scroll through your menus in your instrument cluster using the steering wheel buttons, and find "settings",
then use the steering wheel buttons to navigate through the different options inside the "settings" menu.
The +/- buttons do different functions then the arrow up and down buttons.
Find the time and date setting in there and using the steering wheel buttons change the time.
It should tell you whether to use the arrows or the +/- to change what you need to change.
Old Apr 23, 2021 | 04:31 AM
A1EK's Avatar
Is it not easier just to use the Comand screen mate rather than navigate with the steering wheel buttons?
Old Apr 29, 2021 | 04:33 PM
JojoManigbas's Avatar
SL500
I was able to change the time via the COMMAND system (as per video instructions from Tokyoite).
However after I turn off the engine and start it at a later time (or next) day, the time is incorrect.
It appears the clock resumes running from the time the car was turned off.
ex. 9:30pm parked car overnight. Next morning, @ 8:30am went to car turned on engine - clock displays 9:31pm.
I also have the error B1116 LIN communication between components A1(Instrument Cluster) and A70(Electronic Clock) is faulty.
Plus the digital display is dim (not bright).
Can anyone point me to a DYI fix?
Thanks In Advance.
Old May 24, 2021 | 11:34 AM
MK19's Avatar
Just sold my '11 Porsche TurboS cab for an '03 SL55!
Same Problem on '03 SL55
Hmmmmmmm????
Old May 24, 2021 | 12:44 PM
tonylinc's Avatar
SL55AMG, GL450, SLK, S550, Maserati Coupe
My 2008 SL550 has a Pioneer aftermarket radio, the dash clock is an hour and a half off. I'm thinking of disconnecting the battery at 11:45 and re-connecting right at 12 Noon.
Old May 24, 2021 | 03:58 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
That works, but if you have a friend with star, you should be able to change your programming so that you can set the time (in the dash clock) through the intrument cluster (using steering wheel buttons).
You need Star with Developer mode
The following will enable you to set the hours/minutes in the menu where you normally can only shift between 12H/24H formats
Go to:
"Control units"
"Information and communication"
"ICM - Instument cluster with maintenance interval display"
"Diagnosis to plant specifications"
"Control unit adaptations"
"Control unit adaptations (variant coding)"
"Variantenkodierung Werkseinstellungen"
Scroll down and set "Uhrenverstellung" to "enable"
Old May 25, 2021 | 10:47 AM
SL500
Hmmmmmmm????
Fixed it by replacing the Clock in the center dash.
I purchased a used clock from ebay. The removal of the clock case was simple. Clock itself is held on with 2 screws.
03-09 MERCEDES R230 SL-CLASS CLOCK PARKING SENSORS DISPLAY 0015420314 OEM
Old May 25, 2021 | 11:19 AM
MK19's Avatar
Clock - '03 SL55 AMG
Thanks all. Good ideas here.
Question:
I notice several posts here refer to using the steering wheel menus to access the clock. I can't find the clock via my steering wheel...….what am I missing? I can't seem to get the COMAND to adjust the dash clock.
Old May 25, 2021 | 11:40 AM
Question:
setting the time using the steering controls is normally ONLY available after doing the adaptation I detailed in post 11
Chris
Old Jul 12, 2021 | 03:59 PM
MK19's Avatar
New rear battery solved it and the clock now syncs to COMAND. I was getting persistent "Consumers off line" messages so I'm guessing that was messing with the clock/sync as we know, that battery can cause all kinds of issues........this is apparently one more.
