SL/R230: Program a new key
Old May 3, 2021 | 07:17 AM
spilab's Avatar
SL 55 AMG
Smile Program a new key
Hi,
I bought a new key to my 2004 SL55 AMG with keyless go function, the dealer didnīt program it properly so the keyless function in the key donīt work.
Does anyone know how to program the key so the keyless go function works?
Regards
Old May 4, 2021 | 09:52 PM
Ghostty's Avatar
2005 SL500, 2015 CLS400
Plutoe is correct. I spoke with the service rep from my local dealership, he said that each key needs to be programmed through their system. If they gave you the key and it does not work - they did not complete the process. Unless you had it done at your indy shop, that might require some extra steps, but the result should be the same.
Old May 5, 2021 | 11:14 AM
spilab's Avatar
SL 55 AMG
Hi, i bought the key at a MB dealership and i will return there to fix it.
Thanks.
Old May 5, 2021 | 05:50 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
The keyless entry portion comes set from the factory for your car so your lock unlock trunk panic and starting the vehicle with the actual key will work. This is the Drive Authorization System (DAS). However, the KeylessGo portion must be programmed by the dealer using their computer.
Old May 6, 2021 | 02:27 AM
spilab's Avatar
SL 55 AMG
Gaazmon,
Thanks for the explanation
Old May 6, 2021 | 11:59 PM
gaazmon's Avatar
Originally Posted by spilab
Gaazmon,
No problem. I had learned about this one the hard way lol.
