SL/R230: Drivers Side Corner Molding SL500
Old May 5, 2021 | 09:59 AM
Teambas's Avatar
2020 E350 4Matic & 2012 E350 Convertible
Does anyone have a Drivers Side Corner Molding? Just above the door panel... It is Light Beige or Stone, as someone else told me.
Part # A 230 680 02 78
Below the Part # is: E 0381316 01 (Have no idea what that is)
Old May 5, 2021 | 12:19 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Are you talking about the piece that fits on the end of the dash? If so, the part number you gave is for the RIGHT side. Left side is 2306800178.
Old May 5, 2021 | 02:29 PM
Teambas's Avatar
Now I am thoroughly confused.
But the only thing I am NOT confused about is:
I need a Light Beige Drivers side triangle trim piece, opposite the side view mirror.
Do you have one?
Old May 5, 2021 | 03:00 PM
MikeJ65's Avatar
This?
https://www.ebay.com/itm/113733499077
Here is 2306800278
https://www.ebay.com/itm/324172361769
I don't have one. If you have one with the tab broken, I have a fix for that. Otherwise, the dealer is generally best if your color is still available, about the same price as ebay and not 18 years old.
Old May 5, 2021 | 03:16 PM
Teambas's Avatar
Yep, the tab is broken.
Can you fix that?
Old May 5, 2021 | 06:09 PM
MikeJ65's Avatar
I print repair pieces out of nylon and epoxy them to the stub of the broken one. They fit directly in the door slot, so you just remove the white clip on the door side and install the trim. I'll PM you the details.
Old May 5, 2021 | 06:29 PM
Teambas's Avatar
Thanks much Mike!
