Does anyone know where i can find my accessory batteries in service or manufacture date? Usually it written or stamped on the top and i dont see it, or maybe not reading it correctly. See pics below.
Thanks and not sure if its bad or not, just trying to figure out why my roof wont work properly. Seemed like an easy place to start.
If you have a warning on your dash that says " Convenience Functions not availiable' this is down to a low rear battery. If you have this and drive for about 10 mins it should go and the battery will charge.
If you check with a multimeter that the voltage when engine is on is 14.1V then this is fine.
Depends from device type and matherials. I work on small battery manufactury in my town. Its hard and expensive type of industrial manufacuting. In work we use different tools like https://eltra-trade.com/catalog/siemens-sinamics-s Automation is a broad term applied to any mechanism that moves by itself or is self dictated.
