I recently purchased a 2003 SL55 with roof "issues" once home I found the pump fluid reservoir was very low, I topped it up and the roof started working again.
So it had a leak, which I found fairly quickly at the point the various hydraulic lines enter the pump block particularly line 100. (see pic)
My question is can this be fixed or is it time for a new pump from Top Hydraulics?
Thanks in advance for any help - Graham The two lines at the top seem to be the ones leaking.
