SL/R230: Warm aircon
Old Jul 8, 2021 | 04:08 AM
yelnats69's Avatar
SL 350 2012
Warm aircon
SL350 230
Had my aircon charged and pressure checked,
It blows cooler but not real cold and the aircon light flashes 3 times.
Any ideas?
Will an iCar MB diagnostic scanner check the aircon? or what scanner do I need to buy (private owner use).
Stan
Old Jul 8, 2021 | 08:12 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
I think that the flashing light is for low refrigerant and needs to be reset for the system to resume working. Not an expert on the iCar MB, but I think it should be able to clear AC codes and diagnose the system.
Old Jul 8, 2021 | 01:42 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Yes that scanner ‘does’ the hvac. I presume it should be able to clear historic faults. Sorry, never had this fault so can’t rely on my own experience.
Old Jul 9, 2021 | 11:11 PM
Aussiesuede's Avatar
SL500 & GL450
Originally Posted by Frederick NL
Yes that scanner ‘does’ the hvac. I presume it should be able to clear historic faults. Sorry, never had this fault so can’t rely on my uhown experience.
I can confirm that the iCarsoft MBii can read and erase HVAC faults. The code must be erased anytime the system becomes empty of refrigerant in order to regain AC. If your system is producing anemic AC, it's a good idea to refill it sooner rather than later so you can avoid the need for a reset. Also, the refrigerant provides lubrication to the compressor pulley, so letting it run dry will result in a noisey squeak at the compressor pulley ( a tell-tell sign the system has run dry)
Old Jul 20, 2021 | 05:56 AM
yelnats69's Avatar
SL 350 2012
Originally Posted by yelnats69
SL350 230
Any ideas?
Stan
Thanks for replying to my post, not fixed yet but will post when there is an outcome.
Old Jul 20, 2021 | 06:02 AM
yelnats69's Avatar
SL 350 2012
Thanks Mike, not fixed yet but will post the fix when I do.
Old Jul 20, 2021 | 06:03 AM
yelnats69's Avatar
SL 350 2012
Thanks for the reply, not fixed yet but will post details of the fix when I do
