SL/R230: Help Needed With SL500 Clock
Old Jul 16, 2021 | 09:34 PM
sl500kk's Avatar
SL500
Hello,
I am helping my dad fix the clock on his 2003 SL500. There are two problems:
1) The only thing we can edit is the minutes. When following the instructions SVC > Settings > Date/Time, everything but the minutes is grayed out and we also have this symbol:
I can't find any information about this symbol online.
2) We were originally just trying to update the clock on the head unit. I've seen people online mention syncing the dash with the head unit but I've found no info on how to do this. We can't figure out how to update the head unit clock.
Any help would be great. Thanks!
Old Sep 25, 2021 | 03:31 AM
hydrogen's Avatar
2005 SL500
Hi.
I am not an expert but if you have Command system. That symbol is a satellite you need to have the car outside for a while then you can set the clock. I had same problem when I changed my battery.
after about 15 min outside the clock set itself. I was also able to adjust it.
Old Sep 25, 2021 | 11:32 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
https://www.benzworld.org/threads/ar...d-now.3080849/
