SL/R230: 2007 550 Intermittent Starting
Crank position sensor is a candidate.
Which scan tool do you have?
A heated crank sensor that is about to totally fail, will not allow the engine to start after the starter has spun the engine. A bad EIS or shifter or starter motor/ solenoid relay will not allow the starter motor to turn the engine.
