SL/R230: Changing Climate controls
Old Sep 16, 2021 | 06:16 AM
Anders Lindgren's Avatar
r230 2003
Hi all
My climate control is acting up. The knob in the middle that controls fan speed is loose and fan turns on and off even if I don touch it.
If I replace it what partnumber do I need and is this a simple job not requering Star SDS diagnostics?
have a R230 SL 350 2004
Regards
Andy
Old Sep 16, 2021 | 08:29 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
You shouldn't have to worry about coding, on an '04 the climate control parameters are stored in the CGW (central gateway) module, not in the AAC module. However, the control does need to learn all of the flap motor positions and the potentiometer for the center/side vent control. Sometimes normalizations can be done without DAS (like seats and windows), but I'm not sure about these.
Old Sep 16, 2021 | 08:52 AM
r230 2003
Thanks for help. Do you know correct partnumber for this year model ?
Old Sep 16, 2021 | 11:17 AM
MikeJ65's Avatar
I would need your VIN to be certain.
Old Sep 17, 2021 | 03:59 AM
r230 2003
WDB2304671F081801
Old Sep 17, 2021 | 05:02 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
HOLD ON BRO.. dont buy a new switch just yet,! behind that switch there is a ribbon cable, and contacts to it. I had the same issue and fixed it for the last 4 years with one squirt of WD40 (or a contact cleaner)
You will probably find the contacts just need a clean, try spraying around the edges with WD40 and turn the knob a few times, then see if the random on off and speed changes fix themselves.
Old Sep 17, 2021 | 06:00 AM
r230 2003
Thanks för the tip. I will try it out // Andy
Old Sep 18, 2021 | 10:44 AM
r230 2003
Great it worked with wd40...yes
Old Sep 18, 2021 | 05:04 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Do you mean spraying in/around the round button, without dismantling the thing? No cleaning needed in there afterwards?
Old Sep 20, 2021 | 02:51 AM
r230 2003
I dismantle it and sprayed it. //Andy
Old Oct 27, 2021 | 01:51 PM
Works like a charm for me! No dismantling needed, a few short sprays around the knob, a few turns and Presto. Thanks!
