SL/R230: PSE system
Old Sep 17, 2021 | 07:04 AM
Alan Gauthier's Avatar
Sl 600
PSE system
I am having a minor periodic problem with the trunk soft close. I have read the various posts about sealing the system and replacing the latch. I am not prepared to proceed with any of those fixes because this happens infrequently and I can fix the problem by removing and replaceing the 20 amp fuse. Can anyone give me a short version of how this PSE system works as it relates to my issue. After I reset the fuse the soft close works for weeks then at some point it stops working. I would think that a small vacuum (pressure?) leak would be overcome by the PSE pump. The system works after I reset it so the pump must be working. Why after a period of time would the system not work?
Alan
Old Jan 5, 2023 | 10:50 AM
Jrampon's Avatar
MB SL350 Sport/Infiniti FX35
Soft Closing Trunk
Alan
Hello!
I always have to hit hard for closure. How to solve this problem?
Did you manage to solve?
Thank's.
Old Jan 5, 2023 | 11:02 AM
aeginc77's Avatar
2005 SL 600, 2004 Jaguar XKR, 1998 Corvette, 1975 Porsche 914
I fixed the problem about six months ago by removing the latch mechanism and epoxying all the holes which have small ball bearing in them and any cracks. I had a crack on the side of the latch mechanism. This is a simple job and a simple fix. I followed the posts on this subject and they were right on. The trunk closes perfectly now.
Alan
Old Jan 5, 2023 | 11:24 AM
Jrampon's Avatar
soft close trunk
Wonderful!
Can you post the thread you followed?
Jeff
Old Jan 5, 2023 | 11:37 AM
aeginc77's Avatar
Not sure how to post the thread, but here is the title. The first post is very detailed with pictures. Very simple;;
Have Trunk Soft Close / Trunk Assist problems. Here is how to fix DIY.
Old Jan 5, 2023 | 06:29 PM
Tom Manning's Avatar
2005 SL 500 R230
'Sticky' link at the top of the page:
https://mbworld.org/forums/sl-class-...w-fix-diy.html
Old Jan 5, 2023 | 06:33 PM
Jrampon's Avatar
Tem problemas de fechamento suave do tronco/assistente do tronco. Aqui está como cons
Woohoo!
Thank you very much.
