SL/R230: Limp Mode After Replacing Suspension and Steeting Components
I recently replace all my control arms/ ball joints and tie rods on my SL55. I had some weird squeaks and I figured it was time. I got all the proper tools and wrenched all weekend! It was a PITA even with correct tools. Having a motorcycle jack really helps support the suspension for this job. It cradles the disc and rotors! It didn't help the weather was over 100F and humid as hell.
Took the car for a test drive and she is in limp mode with no faults or codes found with my STAR! I obviously disturbed the alignment after replacing my shot inner and outer tie rods. I did a test only alignment using string etc. just enough to drive it 3 miles to the alignment shop. I also disturbed the ABS speed sensors. I tried doing the reset by turning the steering wheel lock to lock, disconnected the battery (one year new) and rechecked and cleaned the ABS sensors.
After disconnecting the battery, I did finally get a "ESP not Available see owner's manual in the dash." Maybe I'll get more info. after hooking up to STAR again. (which found zero faults with all sensors associated with the front end initially) If anyone has any suggestions from this type of experience it would be greatly appreciated.
18 year old 130K shock arms were still in amazing shape. Bushings still intact.
Lower ball joint and thrust arms were original and were needing of replacement.
Happiness are new tie rod boots!
What is 'limp mode' in this case, not shifting, limited throttle, or something else?
I recheck my work again this morning. All nuts are torqued correctly to spec. Pulled out the ABS sensors again and visually checked them for damage. Charging battery again after leaving it disconnected all night. Btw - I did get “ESP not available” message in the dash yesterday after plugging the battery back. Just a note. I have replaced my batteries once and have disconnected them many times the last year to do other PM and never saw the ESP light come on. Only warning I got battery related was once when the heat here killed the main battery. (Some features may not be available warning)
Thanks for relying and I’ll post more findings later today.
I would start by going to the ESP module and checking wheel speeds as you drive. If they look okay, go to the ESP sensors and the engine CAN data. Maybe the ESP thinks that the car is losing traction or in a skid and is trying to save it. Also reset the steering angle sensor by going lock to lock.
Also, you probably know this, but if the quick scan shows a ! in the last column and no info like p/n on a line, that means that DAS failed to connect to that module. DAS will show all of the mandatory modules whether it can communicate with them or not.
Note: I did forget to plug one of the plunger sensors back in when I started the car for the first time and caused an ABC warning. Duh. Who knows, this may have started a cascading effect. Thanks.
