SL/R230: 2008 SL55 AMG POWER STEERING FLUID LOSS
Old Oct 9, 2022 | 10:11 AM
GeeJayMaj's Avatar
2008 SL55AMG
When I started the car, the steering wheel would not turn either way and a white ABC warning in dash came on. I checked the ABC fluid and was at the correct level but no fluid in the Power Steering reservoir, all the fluid had leaked to the floor.
The car is a 2008 SL55 AMG with 86500 miles. What could have caused this.
Thanks for your input.
Old Oct 9, 2022 | 02:22 PM
Dr. Plastic's Avatar
2005 SL500 & 2021 Jeep Willys Gladiator
A leak!
Old Oct 9, 2022 | 07:58 PM
GeeJayMaj's Avatar
2008 SL55AMG
Dr. Rubber,
Be cool eat fool drink araq Batroun.
Old Oct 9, 2022 | 08:38 PM
Tom Manning's Avatar
2005 SL 500 R230
Well that's helpful.
Are you planning to fix it yourself? It's probably a ruptured hose. Pull the engine sump cover, fill the reservoir if necessary, and see if you can see where the fluid is leaking from.
If it's a hose you can get a hydraulic shop to rebuild it for low cost.
