SL/R230: SL 500 2005
Old 10-26-2022, 05:19 PM
Tom Manning's Avatar
2005 SL 500 R230
Get that current soak test done on that battery.
As mentioned, measuring static voltage is only one factor in battery performance, and measuring the voltage with the car running tells you nothing about the condition of the battery, just the charging system.
I'd be pulling the SAMs though and looking for any water damage to those modules.
Old 11-12-2022, 11:26 AM
WBW
WBW's Avatar
SL500 R230
Finally managed to get it booked in .
Charging was fine to begin with ,then the rear battery jumped to over 18volts .
The front was fine ,then dropped below 12volts .
Fingers pointing towards the alternator .
Old 11-12-2022, 05:42 PM
2005 SL 500 R230
Highly likely it's the regulator, not the alternator. If so then this is available separately.
Over-voltage to the battery module (which charges the front battery) probably caused it to shut down and stop charging.
Old 11-12-2022, 05:48 PM
WBW
WBW's Avatar
SL500 R230
Regulator as in the part attached to the alternator ?
Old 11-12-2022, 11:06 PM
2005 SL 500 R230
It's attached to the alternator, yes. I haven't worked on mine but you can change it without removing the alternator I believe.
It was an early known trouble spot. Mine had the alternator replaced under warranty when the car was a year old.
WBW (11-14-2022)
Old 11-13-2022, 02:05 AM
WBW
WBW's Avatar
SL500 R230
It seems a new alternator has been ordered at a cost of £200+ vat
Old 11-16-2022, 05:13 AM
  #32
WBW
WBW's Avatar
SL500 R230
ABS light is on indicating a wheel speed sensor fault .
Is this a big job to sort out ?
Quick Reply: SL/R230: SL 500 2005
