SL/R230: Transmission shift lever indicator lights?
Old Nov 17, 2022 | 08:51 PM
Dr. Plastic's Avatar
2005 SL500 & 2021 Jeep Willys Gladiator
Question.....When moving the transmission shift lever to each position, is there an indicator light on the panel to the left of the shifter to indicate each of the different positions the lever is in? The instrument cluster right hand display does show gear selected, just nothing on the center panel. If they are suppose to light, this may explain why my C/S transmission mode switch does not work. I wonder if the panel is either dead or the plug came loose.
