SL/R230: TPMS question
Old Dec 3, 2022 | 01:34 PM
O_Dawg's Avatar
2009 SL550 2009 SL63
TPMS question
Do these cars have it? I've tried looking in the manual and searching around and it seems like there is a menu that you should be able to get to that would show each tire's pressure. All I ever get on mine is "tire low" and you just sort of have to guess which one and how much. I feel like I'm missing something here, or maybe mine is just broken.
Any suggestions?
Old Dec 3, 2022 | 05:44 PM
g0rsq's Avatar
SL500
Mercedes did use a software version of TPMS, which compared the rotation speed of each wheel using the ABS sensors. If a tire was going flat, its effective diameter (and circumference) reduced, meaning it would need to rotate faster than the others.
Not sure if it was available on the R230 though.
I had a R171 SLK and was able to turn it on using STAR SDS. Worked quite well, detecting a slow puncture. You only got warning message on dash, no indication which wheel.
Full TPMS, with sensors in each wheel was an option.
