SL/R230: Abc issues and car won’t raise.
Old Feb 17, 2023 | 10:36 PM
jhicks6967's Avatar
Sl500
Seeing if you guys can shed some light. This am was heading to the gym, heard a loud bang thought I hit something in the road. The abc warning in red came on and won’t go off. Little history the abc will flash and go off when I hit a speed bump too hard. Also when it sits for a hour or so the left front will drop, but will lift once I start the car. Now the whole left side is very low and won’t raise. Also right looks lower than normal. I checked and the reservoir is empty and I noticed fluid on the wet pavement at gym. Just wondering if anyone can shed some light on it and give me a idea where to start. 04 sl500
Old Feb 18, 2023 | 07:25 AM
cdk4219's Avatar
95 SL600
You blew one of the ABC hoses, and more than likely have run the pump dry. Get your wallet out, it’s going to be costly
. I would say the pump, one or more of the hoses and at least one of the valve blocks are going to need replacement, along with all of the accumulators, which probably went bad quite some time ago and disregarding the ABC light has led to a blown hydraulic hose.
Old Feb 18, 2023 | 09:01 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Best case, the fluid was by the left rear wheel and you blew the rear pressure line and didn't drive far enough to ruin the pump. That would be a few hundred bucks including the accumulators if you can do the work yourself. A couple grand at an indy shop.
Old Feb 18, 2023 | 05:15 PM
g0rsq's Avatar
SL500
Probably all caused because to continued to drive with a blown accumulator! The accumulators act a fluid shock absorbers.
Hope you haven't destroyed the pump, but should act as a lesson not to ignore maintenance on these cars. What would have cost a few $100 will now cost a few $1000, if not scrap the car!
Old Feb 18, 2023 | 10:08 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
Last year my pump went bad and had a serious leak. MBZ didn't have a replacement pump anywhere - claimed it was due to the supply train issues. I bought a rebuilt pump from a German rebuilder for about $800 including shipping. Good luck!
Old Feb 20, 2023 | 03:13 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
Perhaps a coil over conversion will be cheaper and free of headaches in the future!
Sell the hydraulic shocks and will be a lot cheaper to convert!
Old Feb 22, 2023 | 08:13 AM
O_Dawg's Avatar
2009 SL550 2009 SL63
Oooof, that is going to be rough. I love the ABC system, but after a failure like that, it might be time to consider a coil over solution. These guys sell a kit that comes with all the stuff you need to switch it out. I believe they are out of Florida.
https://vvk-usa.myshopify.com/produc...50-sl600-sl350
Old Feb 26, 2023 | 09:31 PM
George993's Avatar
2014 E350 Wagon, 2009 SL550 no ABC
I believe that the only correct way to repair ABC system on R230 is to replace it with coil overs, I would not buy or drive a R230 with ABC (after my extensive ABC experience). Unless the car is only driven slowly and on short distances and you are always prepared to have it towed home.
Old Feb 27, 2023 | 04:44 PM
g0rsq's Avatar
SL500
Should read....
I believe that the cheapest way to repair ABC system on R230 is to replace it with coil overs,
Old Feb 27, 2023 | 05:18 PM
cdk4219's Avatar
95 SL600
“and you are always prepared to have it towed home”
On a flatbed that will destroy the front bumper because it’s on the ground, and hopefully nobody turns the wheels and catches the front fenders causing damage. Not to mention it will probably scrape the exhaust tips on and off the flatbed. Mercedes and their air and hydraulic suspensions!
Old Feb 27, 2023 | 05:53 PM
George993's Avatar
Should read....
Certainly cheaper than spending $10,000-$20,000 to completely replace ABC with new components :-). But not necessarily cheaper than replacing a single blown hose. If you only spend a few thousands to replace the shocks for example, the next thing could be a spectacular blow up of a high pressure hose (ask me how I know - the exact case of one of my ABC cars). Or it could be a vertical acceleration sensor failure with the car suddenly starting to violently jump up and down on a perfectly flat highway in heavy traffic at 60mph (again ask me how I know). Plus add the cost of repairing the bumper/body damage from getting the low car on/off a tow truck. Or funeral costs if a hose blows up during a fast drive on a winding mountain road. Maybe a great system when new, but not so on cars approaching 20 years of age.
Old Feb 27, 2023 | 05:57 PM
George993's Avatar
BTW, for those familiar with "rodeo" test on ABC - that's how it feels in the above case at 60mph, not something for people with limited driving skills to safely recover from.
Old Feb 28, 2023 | 03:46 PM
cdk4219's Avatar
95 SL600
It’s a terrible system and even more so when you think about what actually could happen when it goes bad. Those who love it can defend it all they want, but they don’t understand the ramifications when it breaks.
Old Mar 3, 2023 | 10:26 AM
imtheking's Avatar
Former R230, W220 and W221 owner
There's a guy on Youtube that posts videos installing the NeoMax coilovers for customers. He's a big fan and his customers give rave reviews
