SL/R230: 🤔 🚨 Battery Warning light 🚨 ?
Old Feb 20, 2023 | 07:30 PM
dowrt9's Avatar
2006 M-Benz SL 500
Battery Warning , Visit Work Shop 🤔 ?
New to the mbworld.org
2006 M-Benz SL 500
I would like to ask for some advice, please?
I have a Red Battery Icon & Visit Work Shop message.
The engine compartment battery was tested at advanced auto parts & it was good.
I replaced the trunk battery, but still get the same battery warning once in awhile.
The engine compartment battery's negative cable was disconnected, voltage reading was 13.04 V
The trunk battery voltage reading was 12.99 V ,
with front/engine battery's disconnected.
2006 M-Benz SL 500
Old Feb 20, 2023 | 09:08 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Have you tried to clear the code using OBD port and suitable tool? Is your charging system working properly?
Best practice is MB specific tools like Xentry or a Foxwell with MB capabilities.
Good luck and keep us posted.
Old Feb 21, 2023 | 02:16 AM
Tom Manning's Avatar
2005 SL 500 R230
It seems de rigueur, after having replaced the rear battery, that the red code pops up. It will most likely not reappear after you clear it out.
Old Feb 21, 2023 | 04:19 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Never disconnect the front battery while the rear battery is connected.
Old Feb 21, 2023 | 05:10 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
I think you have confused the car, use a code reader to see if you can clear the codes. For icarsoft you go into battery maintenance if you happen to have one thats how I cleared mine. Also check that your car is charging, on the off chance that your voltage regulator or alternator are playing up. Simple use multi meter on your cigar lighter and with the car engine on, it should read about 14.1V. Turn on rear heater, lights and see if the volts dip then come straight back up to 14V.
Old Feb 21, 2023 | 06:29 AM
dowrt9's Avatar
2006 M-Benz SL 500
Thank you for your advice.
The cigarettes lighter voltage reading was 14.3-14.4 with the engine running .
I will take pictures of voltage reading at both batteries & at the cigarettes lighter soon .
Old Feb 21, 2023 | 07:32 AM
A1EK's Avatar
Perfect your car is charging nice, did you check the voltage regulator by turning on the lights and rear window heater or seats, it should remain at the same level.
Old Mar 11, 2023 | 11:57 PM
maxorbit's Avatar
300E
I rest my battery alarm with my icarsoft code reader. We have 2 MBs and this is a nesesity to have. athough our SLK55 rarely needs it.
