SL/R230: 2005 Sl500: Need to Replace Battries
Old Feb 22, 2023 | 07:08 AM
TheSpooky's Avatar
2005 SL500, 2022 RX350, 2016 GLC300 4Matic(Sold), 2008 RX350 (sold), 2003 RX300(sold)
My newly acquired car has non MB batteries.
At the moment it has:
Main/Front: Interstate MTP-V4, a non AMG... is older of the two.
Aux/Rear: Interstate MTX-48/H6 a AMG type..newer with a date sticker of 12/22.
Could someone please share part # for the corresponding MB batteries.
Also, some tips on how to swap these batteries.
After swapping do I need to code the batteries.
I am sure some consumer functions will be lost after the exchange. What are those and how to reset them?
Thanks.
Old Feb 22, 2023 | 03:08 PM
TheSpooky's Avatar
Picked up fresh batteries from MB dealership.
230-541-00-01 Front/Starter
001-982-80-08 Rear/Auzxillary
Price is similar to non MB batteries.
Old Feb 22, 2023 | 04:25 PM
Tom Manning's Avatar
2005 SL 500 R230
Disconnect and remove rear battery: negative, then positive
Disconnect and remove front battery: negative, then positive
Replace front battery: positive, then negative
Replace rear battery: positive, then negative
Turn the car on and reset the windows by holding the switches up fully until all four windows close all the way.
If you get the 'ESP unavailable' message, turn the wheel lock to lock to reset.
If you get a red 'Battery defective - visit workshop' message you will need a scan tool to reset it. It can't be done any other way
Don't bother resetting the clock - it will reset via the GPS.
Old Feb 22, 2023 | 08:39 PM
TheSpooky's Avatar
I did exactly as you suggested and reinstalled new battery(s). Car started right away.
I did the ESP reset routine and that message is gone.
Thanks.
Old Feb 24, 2023 | 01:18 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
For what it’s worth, MB batteries are made by Interstate, per the parts manager at a local MB dealership. At least USA cars, that is.
