SL/R230: 2005 SL500: Another ABC victim
Old Feb 23, 2023 | 07:21 PM
TheSpooky's Avatar
2005 SL500, 2022 RX350, 2016 GLC300 4Matic(Sold), 2008 RX350 (sold), 2003 RX300(sold)
A little background:The car was purchased in California and transported to NJ. It is claimed that all functions were working as expected at the time of shipment. However, when delivered ABC red warning was on and after few starts car refused to start. Car was found to be equipped with a non AGM starter and an AGM Aux battery (both non MB). Aux battery had drained to ~4.5 Volts (which was deemed to be end of the battery).
Actions/Observations:As a first intervention both batteries were replaced with OEM MB batteries, after which the car started right away and red ABC warning changed to white and "car too low" remained on. However, car responded to height elevation command via the center console. While driving, the steering felt a little tight but no tire scrubbing was noted.
Seller suggested to disconnect and reconnect (after 30 minutes) main battery to resolve ABC warning, which didn't.
Seller than suggested to remove fuse 13 & 46 ( noted to be good/not burned) and drive. Removal of fuse(s) made ABC warning disappear and steering felt as normal. Car was driven about 3 miles to get some gas. No drive-ability issues were noted during this drive. However, upon restart after refueling, ABC(white) warning returned and remains. Upon return fuses were reinstalled with no consequence on ABC warning.
Full quick scan with Foxwell NT510 Elite didn't show any codes related to ABC. However, upon changing full to component scan, scanner repeatedly returned "unable to trigger" suspension scan. (This is the first time I am using this scanner, so I am not very experienced with its capabilities. Someone has shown that it can do rodeo during ABC flush).
There is no fluid leak/overflow or funny sounds when starting/driving.
Please share your thoughts for the next step to correct this.
Old Feb 23, 2023 | 07:54 PM
Tom Manning's Avatar
2005 SL 500 R230
What is the exact warning: Stop - car too low? That's a red warning.
Or is it ABC visit workshop - a white warning? That can indicate an internal leak in the valve block, which is not serious. Please clarify the exact message you're getting.
Battery issues and ABC warnings are usually not connected (although you can have both at once...)
Old Feb 23, 2023 | 08:04 PM
TheSpooky's Avatar
Initially it was red & "car too low" , when batteries were dying. Once I replaced batteries it changed to white with blue background and "car too low", now it is white with blue background "Display Malfunction, Visit workshop"
Old Feb 23, 2023 | 08:46 PM
2005 SL 500 R230
Try the scan again. There must be a code or two.
Dying battery can throw up some strange codes, but maybe they're all stored and not current.
Old Feb 24, 2023 | 12:06 AM
TheSpooky's Avatar
Most were stored but there are several current. I will re scan and report some.
