SL/R230: Park brake cable
? Any insights?
Perhaps begin by removing the trim under the wheel and see if you can see what's broken in there. You might have to remove the two panels on the side of the console first.
It should be pretty obvious where the damage is, then probably you'll be able to repair it yourself.
If you can pull out the handle (part #110) entirely without seeing the cable (part #90) attached, this might mean the cable is loosed.
The cable should be attached like the following pic.
Hope this shed some light into your problem.
