SL/R230: Not crank, help please.
You can start and run the car without the rear battery. Something is wrong in the starting circuit.
First try to jump start the car from the front battery and see what happens.
The starter motor died without warning on my 2003 500sl at about 125kmiles. Turn key and hear click, no crank.
Jump start the car with high amp jumper. See if the car starts. If the front battery is dead, no trickle charger will bring it back to life. This is what happened to me. Tried trickle charger and jumping the car with cables running from another vehicle and nothing.
Bought a high end, high amp jumper and the car started right up. When I disconnected the jumper and turned the car off, dead again.
I say all this to say- you may need a new starter battery.
Never had anything like this with my 03. But I don't have the keyless go with my car.
