SL/R230: Overheating Help!
I did recently replace the water pump, thermostat, and radiator, but not radiator fan or coolant temp sensor. I also added a larger heat exchanger, and swapped the secondary IC pump to the Bosch, but I didn't split the system. There's no coolant leaks that I've seen so far, but I would still think the car should always be running at about 80* C? I don't know how to check for air other than running it with the heater at full blast for a while. It doesn't have the bleed nipple that the E55 has. Is there a better way to bleed the system? Is there anything else I can check or do to get this running right? Currently I don't want to drive it over a few mules for fear of it overheating. Thanks.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
