SL/R230: Boot Not Shut
Old May 25, 2023 | 07:58 PM
Twoturntables's Avatar
2003 SL500
Originally Posted by MikeJ65
If the red light stays on when you close the latch with the trunk open, you have an issue with the micro switch, wiring, or a module. There are two switches under the round, black release servo. Start by checking them and the wiring to them. One reads the initial click/safety latch, the other the final, full lockdown. Both have to be recognized for the roof to function.
Mike.. Thanks for the all of the tips here. So I took the mechanism out again, I believe I had the servo style control arm with the ball and cup connection on the end, I believe I had that connected to the mechanism wrong. Instead of left to right, I had it going in right to left. So I changed that and reassembled and boom, no red light when I activated the soft close. So put it all back together and the top opens! How thankful I am! So my last question is, how do I know if the trunk closes too tight? When I open the trunk it pops a little when it releases. Does this sound correct? If not, should I make a slight adjustment or just leave it?
Thanks again!
Jim
