SL/R230: 2007 SL550 Hard top not fully latching
If the latch is actually locked, you have an issue with reading the status of the locks. Check S69/2, S69/3, and the wiring from the switches to the roof control.
If the latch is unlocked, for some reason it is not latching even though the pump and this specific hydraulic circuit are activating. Possible issues would be internal bypass in the front latch cylinder or possibly in one of the other cylinders on that circuit, front cylinder hoses installed backwards, front cylinder hoses attached to other incorrect ports on the pump, or a mechanical issue with the latch.
Check fluid level, this can be an indication of low fluid. If it is low, refill and find your leak.
