SL/R230: Clima problem
Old Aug 6, 2023 | 05:21 PM
911911911's Avatar
Sl 55
Clima problem
Ciao a tutti.
Ho un problema con il climatizzatore.
Esce aria fredda solo direzione piedi.
Non è possibile modificare la temperatura.
Non è possibile modificare direzione aria.
Report diagnosi:
Sembra un problema noto.
Help
Old Aug 9, 2023 | 01:27 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Those are communication faults. When you have all of those, it is probably that the servo connector socket is off of the AC control. All of the servos are on one harness. If you had the radio replaced or other work done in that area, it is likely that it just didn't get plugged back in.
Old Aug 15, 2023 | 02:25 AM
911911911's Avatar
Sl 55
Ho controllato e tutto ok.
Hai schema elettrico?
